Frequent Contributor II
MOBILITY controller setting for voice
hello Airheads,
our customer would like to deploy a mobile phone app to use the wireless infrastructure (2.4GHZ\5GHz).
They already have an Aruba WLAN (MOBILITY CONTROLLER) and would like to know how they can ensure
good QOS and traffic prioritization for the phones running this app. It is the Shoretel communicator app and the
voice gateway i believe will be hosted local to the site.
Thanks in advance Pete
Re: MOBILITY controller setting for voice
If I understand this correclty, app is basically a VoIP softphone.
Therefore you canrefer to the "Voice over IP (VoIP) Deployment with Aruba Mobility Access Switch application note" when setting up the network.
The practices in this appnote should applicable to the VoIP traffic from that smartphone app, just the same as from any other VoIP client.
You can find the document here: http://www.arubanetworks.com/wp-content/uploads/VoIPwMASAppNote-20120726.pdf
-ACMX #352-
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
thanks for reply not really what i am looking for.
I am looking for a start to finish set up on an Aruba controller to include the ssid settings in the vap,
WMM through to the DSCP settings. I have been through the controller user guide but i was just wondering
if a design ref guide was available.
cheers
Pete
The link made above is likely the best source short of manually peicing the parts you need together out of the UG. WMM, DSCP, etc are all covered there.
Jerrod Howard
Trusted Contributor I
you guys sure the read the document? it is mainly about how to connect wired voip phones, there really is nothing on DSCP, WMM, and wireless things for voice.
spend some more time collecting info (see below), the high level principles are clear, would be nice to have some specific tips and caveats.
voice on RAPs (title says controller, but chapter 2 clearly says Best Practices for Voice Deployment at Remote Sites):
http://www.arubanetworks.com/wp-content/uploads/VoiceSupportAppNote_2011-11-14.pdf
voice on wired networks (mainly on detecting phones and setting up pc behind phone):
high level VoWLAN document:
http://www.arubanetworks.com/pdf/technology/TB_Voice-Over-WLAN.pdf
table 19 in this document comes the closest to actual "configure these" advise:
http://www.arubanetworks.com/vrd/80211nNetworksVRD/wwhelp/wwhimpl/js/html/wwhelp.htm#href=Chap6_WiFiMultMedia.html
this is probably a very useful document if you were at the session, now it again points to things but without the context it is difficult to judge the exact actions needed:
http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/AirheadsConf-LV-2013-Breakout-Wireless-LAN-Optimizing-Wi-Fi-for/ta-p/69758
were those break out sessions taped?
serie of 4 best practices information (high level, no config) from 2011
http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Best-Practices-for-Voice-over-Wi-Fi-Part-1/ta-p/16473
http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Best-Practices-for-Voice-over-Wi-Fi-Part-2/ta-p/16475
http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Best-Practices-for-Voice-over-Wi-Fi-Part-3/ta-p/16479
http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Best-Practices-for-Voice-over-Wi-Fi-Part-4/ta-p/16481
serie of 4 planning information (high level, no config) orginally from 2007
http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Checklist-for-Planning-a-Voice-Over-Wi-Fi-Network-LAN-Planning/ta-p/25698
http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Checklist-for-Planning-a-Voice-Over-Wi-Fi-Network-Wi-Fi-Coverage/ta-p/25700
http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Checklist-for-Planning-a-Voice-Over-Wi-Fi-Network-Quality-of/ta-p/25702
http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Checklist-for-Planning-a-Voice-Over-Wi-Fi-Network-Security-and/ta-p/25704
All the links given below are broken. Can the fresh links be refreshed concerning this problem statement.
All the links in the post right above yours work.  Which link are you referring to?
Alternatively, you can do a search for anything related and should be able to find what you want.
Contributor II
No Ducuments within this article works.  Has Aruba given up on the VoWLAN?  Are they doing something different?  I know that most of the docxuments on this page do not work...
Which voice device are you using?  Those links are pretty old and technology moves pretty fast.
