MSR 2000 to point to controller captive portal
Not sure if this is possible, but I would like to point a MSR 2000 or two to the captive portal page and vlan of an aruba controller 650 for guest access.  Is that something that can be done?
Re: MSR 2000 to point to controller captive portal
Just send the wired traffic from the MSR to an untrusted wired port on an Aruba 650.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
