MSR2000 Wireless Mesh Router
Can we use MSR2000 as wireless access point only?
When we catagorize this product, whether we should consider it as WAP or router?
Re: MSR2000 Wireless Mesh Router
Yes you can either use the two radios on MSR2000 for client coverage  or as mesh backhaul.
I think they are consideres as WiFi Mesh routers as they have full routing capabilities.
I have 2 number MSR 2000 in that i need to configure point to point .what is the configuration setup i need to do .
I am new to Aruba networks.
Regards
N.Muthusaravanakumar
muthu@texonic.com wrote:
Regards
Please see Chapter 6 of the outdoor VRD here:  http://www.arubanetworks.com/wp-content/uploads/AP_OutdoorPointToPoint.pdf
Hi ,
i have configured but it is not communication ..... any other changes. please let me know .
Os version :- 4.5
I cahged the host name :- node 1                                                       host name :- node2
wireless -radio :- set mode channel :- 802.11 na .40 mhz             same
set antenna gain to :- 14        same
Backhaul
Auto wds meshing :- enabled                                                               same
max allowed links  :- 1        same
short GI :- enable        same
nighbor distance :- 1000        same
wirless setting
Mesh :- mesh networkid  MSR                                                             same
security
wpa2        same
service setting : VPLM  -enabled                                                           same
Regards
N.Muthu
Do you have antennas connected to ach unit?
 yes .
model ANT 2*2 -5614
 it is connected in radio 0
