Frequent Contributor II
MSR2K Antenna Mount
Does MSR2K support direct antenna mount ? if not what cables are needed ?
Re: MSR2K Antenna Mount
Yes. The MSR2k has 4 N-type connectors and support direct antenna mount.  Remember to use lightning arrestors.
Thx
what about MSR4K ? does it support direct antenna mount ?
i remeber that one Model of MSR  doesn't support direct Antenna mount & so the 7D cables is mnadatory for it ( not Optional ) ?
