EP
MSR4000 and Ant-5614
Hello's
I had a quick question. I note that the config guide for the MSR4000 does not list the ant-5614 as a possible antenna while it does so for the MSR2000.
My question is, why can't I use the 5614 with the MSR4000, while I can use it with the MSR2000?
Thanks for your time,
Sky
MVP
Re: MSR4000 and Ant-5614
You can use the 5614 with the MSR4000, Ii's likely an oversight on the documentation side. I have numerous deployments using multiple 5614s on a single MSR4K working just fine.
Jerrod Howard
Sr. Techical Marketing Engineer
EP
Thanks much Jerrod,
Sky,
