Occasional Contributor I
MacBooks connection problem
I am trying to connect wifi with macbook but i can't . If i try  with other devices without macbook which are android, pc, linux, iphone or ipad etc., there is no any problem.
do you have any experience about this problem?
Thanks in advance.
Re: MacBooks connection problem
Hi.
What Aruba OS version  using?
The controller is Aruba 650 and also version is 6.1.3.3. Is there any problem or bug about this version?
Are you using encryption?
No, i am not using.
I am just using Mixed type authentication as wpa2-psk-aes, wpa2-psk-tkip.
Please consider using a single encryption.
