Frequent Contributor I
Maintenance => Backup Flash files
What is the expected. normal file size for a Backup Flash file? I created one on a local (backup) 3600 controller and file size was 64Kb. Did the same on a master (backup) 3600 controller and file size was 19,850Kb. I would imagine the second was is larger than normal, but not sure why that would be the case. Haven't yet created Backup Flash files of the local (active) 3600 nor master (active) 3600 controller for comparison sake.
Tony
Re: Maintenance => Backup Flash files
It is expected that the master be larger than the local, because more centralized data is stored there.
Thanks Colin!!!
