Contributor I
Management Interface ACL
I like to have a management interface ACL feature as before. Can anybody have that idea? Is there  a possibility to be implemented in near future?
Like HP;
   ip authorized-managers 10.0.0.1 access manager
or lots of any other vendors.
Thanks in advance.
Re: Management Interface ACL
You could apply an ip access-group to the interface going to your uplink switch allowing only the ip segment you want allow to access the controller
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor I
Yes. This method also recommended elsewhere but it has some difficulties. It is more reasonable to add just one line solution. Even *nix has this feature, hosts.allow/deny. Why aruba does not have?
Best regards.
Husnu Demir.
Super Contributor II
Can you please provide the sample configuration for the same ?
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
Contributor I
Here is the tip of Aruba.
http://community.arubanetworks.com/t5/Community-Knowledge-Base/How-to-Allow-or-Block-Management-of-the-Aruba-Controller-only/ta-p/27494
Neverthless, aruba engineers did not respond this req for a long time.
hdemir.
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
We are currently using such an ACL.
However it creates difficulties and problems.
Any time a new interface is added to the controller, it should be added to the ACL also.
Furthermore adding the ACL to the uplink port is not enough. It  should be added to all active interfaces and roles such as wireless or vpn roles.
Last but not the least important problem is; the requirement for firewall licence. Such ACL is only possible if he controler has firewall licence. It is not a good idea to need firewall licence just to protect the device itself, in situations where firewall for the users is not required.
Contributor I
Yes, I forget to tell the firewall licence. If you need to protect the controller, which is a MUST, you sould buy the firewall licence even if you did not need any firewall for users.
hdemir.
