Management Users password expire
Hi all
When i create a user ( Manager on GUI and CLI) i want to define user password expire date. For example 90 days later user must change password. How can i do that?
Thank you.
Re: Management Users password expire
You cannot do that.  The restrictions you can place on management users is here:  http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/Management_Utilities/Management_Password_Poli.htm
For the password expiry, you would need to us an external system and have the controller authenticate to that system.
Colin Joseph
Aruba Customer Engineering
