Frequent Contributor I
Manually IPed Access Point and Enabling CPSEC
If I manually configure 100 APs with static IPs and then later enable CPSEC, will the manual configuration on each AP be cleared when they reboot?
N
Re: Manually IPed Access Point and Enabling CPSEC
You should not have a problem.
