Occasional Contributor I
Master Clients and Local Clients
I'm very new to Aruba. I have one question regarding Master - Local Setup.
In Master - Local setup
1. Master will have Menu to Display ALL (WLC, AP, WL Client etc...) in Monitoring
2. Local don't have Display ALL in Monitoring
My question is
in Dashboard > Clients   or in Monitoring > clients
This will show only client that connected to each controller. Am i right ?
If i want to see all client, i've to goto Master controller > Monitoring > All WLAN clients. Am i correct?
Is there any configuration that will show client on both controller in Dashboard > Clients menu
Best Regards,
Supakij K.
Re: Master Clients and Local Clients
My question is
This will show only client that connected to each controller. Am i right ?  Correct
If i want to see all client, i've to goto Master controller > Monitoring > All WLAN clients. Am i correct?  Correct
No. You would have to login to the local controller to see that.
Best Regards,
Supakij K.
Thank you Joseph. Your reply is very clear for me.
