Occasional Contributor I
Master Discovered but AP's not showing in controller
Hi All
I recenlty purchesd 2 x 325 AP, 1 x 7005 controller and 1 x 2920 switch for my lab. When trying to configure the controller I can connect to it and configure using the web based gui,ssh and console however neith of the AP's can be seen in the console depsite them discovering the controller. The controller is licensed for 2 x AP, DNS setting for Aruba-Master configured and ADP works as well.
I can ping the controller from the AP's and I can ping AP's from controller.
Aruba OS 6.4.3.4 on controller
Aruba OS 6.4.4-0-wave2 build 49847 on AP's
Output from AP shown below
(Aruba7005)
User:
APBoot 1.5.4.12 (build 50907)
Built: 2015-07-19 at 20:53:12
Model: AP-32x
DRAM:  235 MB
SF:    Detected MX25U3235F with page size 64 kB, total 4 MB
Flash: 4 MB
NAND:  132 MiB
PCIE0: link up
PCIE1: link up
       dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
       00  00  168c  0040 00002   00 00000004 00000000 00000000 00000000
Power: 802.3af POE
In:    serial
Out:   serial
Err:   serial
Net:   eth0, eth1
Radio: qca9990#0, qca9990#1
Reset: cold
FIPS:  passed
Hit <Enter> to stop autoboot:  0
Checking image @ 0x0
Invalid image format version: 0x0
Checking image @ 0x2000000
Copying image from 0x44000000
Image is signed; verifying checksum... passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
[    0.000000] Booting Linux on physical CPU 0
[    0.000000]
[    0.000000] Aruba Networks
[    0.000000] ArubaOS Version 6.4.4.0-wave2 (build 49847 / label #49847)
[    0.000000] Built by p4build@cyprus on 2015-04-30 at 14:49:32 PDT (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) )
[    0.000000] CPU: ARMv7 Processor [512f04d0] revision 0 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] Machine: Qualcomm Atheros AP148 reference board
[    0.000000] Flash variant: default
[    0.000000] msm_reserve_memory: 0x44600000, 0x200000
[    0.000000] memory pool 3 (start 4fc00000 size 400000) initialized
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] smem_find(137, 80): wrong size 72
[    0.000000] socinfo_init: v6, id=204, ver=2.0, raw_id=2313, raw_ver=2313, hw_plat=0,  hw_plat_ver=65536
[    0.000000]  accessory_chip=0 hw_plat_subtype=0
[    0.000000] PERCPU: Embedded 8 pages/cpu @c0fc1000 s10688 r8192 d13888 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 58154
[    0.000000] Kernel command line: console=ttyHSL1,9600n8 rdinit=/sbin/init ubi.mtd=aos0 ubi.mtd=aos1 ubi.mtd=ubifs
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 49MB 180MB = 229MB total
[    0.000000] Memory: 218068k/224212k available, 16428k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xcf000000 - 0xff000000   ( 768 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xceb00000   ( 235 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc06887dc   (6658 kB)
[    0.000000]       .init : 0xc0700000 - 0xc0c029c0   (5131 kB)
[    0.000000]       .data : 0xc0c04000 - 0xc0cef4a0   ( 942 kB)
[    0.000000]        .bss : 0xc0cef4c4 - 0xc0dbf978   ( 834 kB)
[    0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS:1689
[    0.000000] sched_clock: 32 bits at 32kHz, resolution 31240ns, wraps every 134175798ms
[    0.150390] Calibrating delay using timer specific routine.. 12.55 BogoMIPS (lpj=62792)
[    0.150421] pid_max: default: 32768 minimum: 301
[    0.150890] Mount-cache hash table entries: 512
[    0.152358] CPU: Testing write buffer coherency: ok
[    0.152577] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.152577] hw perfevents: enabled with ARMv7 Krait PMU driver, 5 counters available
[    0.152702] Setting up static identity map for 0x41894da0 - 0x41894e28
[    0.154920] CPU1: Booted secondary processor
[    0.154982] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.155076] Brought up 2 CPUs
[    0.155107] SMP: Total of 2 processors activated (25.11 BogoMIPS).
[    0.169290] dummy:
[    0.169915] NET: Registered protocol family 16
[    0.170665] AXI: msm_bus_fabric_init_driver(): msm_bus_fabric_init_driver
[    0.172977] meminfo_init: smem ram ptable found: ver: 0 len: 5
[    0.173008] Found 1 memory banks grouped into 8 memory regions
[    0.173477] gpiochip_add: registered GPIOs 0 to 151 on device: msmgpio
[    0.174258] smem_find(137, 80): wrong size 72
[    0.174289] socinfo_init: v6, id=204, ver=2.0, raw_id=2313, raw_ver=2313, hw_plat=0,  hw_plat_ver=65536
[    0.174289]  accessory_chip=0 hw_plat_subtype=0
[    0.174320] msm_rpm_init: RPM firmware 3.0.16777342
[    0.181318] clk_tbl_nss - loaded
[    0.205748] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.205779] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.206154] msm_dmov_memcpy_init: Success
[    0.212652] sps:BAM 0x12244000 enabled: ver:0x5, number of pipes:20
[    0.212683] sps:BAM 0x12244000 is registered.
[    0.212902] sps:sps is ready.
[    0.250765] msm_pcie_setup: link initialized
[    0.251077] PCI host bridge to bus 0000:00
[    0.251077] pci_bus 0000:00: root bus resource [mem 0x08000000-0x0fefffff]
[    0.251577] PCI: bus0: Fast back to back transfers disabled
[    0.251577] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.252296] PCI: bus1: Fast back to back transfers disabled
[    0.290877] msm_pcie_setup: link initialized
[    0.291190] PCI host bridge to bus 0000:02
[    0.291190] pci_bus 0000:02: root bus resource [mem 0x2e000000-0x31efffff]
[    0.291658] PCI: bus2: Fast back to back transfers disabled
[    0.291690] pci 0000:02:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.292471] PCI: bus3: Fast back to back transfers disabled
[    0.411215] msm_pcie_setup: link initialization failed
[    0.411433] pci 0000:02:00.0: BAR 8: assigned [mem 0x2e000000-0x2e1fffff]
[    0.411465] pci 0000:03:00.0: BAR 0: assigned [mem 0x2e000000-0x2e1fffff 64bit]
[    0.411496] pci 0000:02:00.0: PCI bridge to [bus 03-03]
[    0.411527] pci 0000:02:00.0:   bridge window [mem 0x2e000000-0x2e1fffff]
[    0.411590] PCI: enabling device 0000:02:00.0 (0140 -> 0143)
[    0.411652] pci 0000:00:00.0: BAR 8: assigned [mem 0x08000000-0x081fffff]
[    0.411683] pci 0000:01:00.0: BAR 0: assigned [mem 0x08000000-0x081fffff 64bit]
[    0.411715] pci 0000:00:00.0: PCI bridge to [bus 01-01]
[    0.411715] pci 0000:00:00.0:   bridge window [mem 0x08000000-0x081fffff]
[    0.411777] PCI: enabling device 0000:00:00.0 (0140 -> 0143)
[    0.427428] bio: create slab <bio-0> at 0
[    0.429365] spi_qsd spi_qsd.5: master is unqueued, this is deprecated
[    0.431552] spi_qsd spi_qsd.6: master is unqueued, this is deprecated
[    0.433895] usbcore: registered new interface driver usbfs
[    0.434270] usbcore: registered new interface driver hub
[    0.434520] usbcore: registered new device driver usb
[    0.435395] i2c-gpio i2c-gpio.0: using pins 24 (SDA) and 25 (SCL)
[    0.437925] Switching to clocksource gp_timer
[    0.441080] NET: Registered protocol family 2
[    0.449359] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.449953] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.450078] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.450171] UDP hash table entries: 128 (order: 0, 4096 bytes)
[    0.450203] UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
[    0.450577] NET: Registered protocol family 1
[    3.171602] Detected 5 counters on the L2CC PMU.
[    3.172852] smd: register irq failed on wcnss_a11
[    3.172852] smd: deregistering IRQs
[    3.172914] SMD: smd_core_platform_init() failed
[    3.173726] smem_find(427, 104): wrong size 88
[    3.173758] get_bootconfig_partition: no dual boot info in shared memory
[    3.188722] enable timer on core 0
[    3.188722] enable timer on core 1
[    3.188753] MSM Watchdog Initialized
[    3.188784] acpuclk-ipq806x acpuclk-ipq806x: SPEED BIN: 0
[    3.188815] acpuclk-ipq806x acpuclk-ipq806x: ACPU PVS: 1
[    3.195657] acpuclk-ipq806x acpuclk-ipq806x: CPU0: 6 frequencies supported
[    3.195688] acpuclk-ipq806x acpuclk-ipq806x: CPU1: 6 frequencies supported
[    3.197157] msm_rpm_log_probe: OK
[    3.215963] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    3.215995] jffs2: version 2.2. (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) © 2001-2006 Red Hat, Inc.
[    3.217307] msgmni has been set to 425
[    3.221774] io scheduler noop registered
[    3.221774] io scheduler deadline registered (default)
[    3.375601] msm_serial_hs module loaded
[    3.375757] msm_serial_hsl: detected port #1
[    3.375913] msm_serial_hsl.1: ttyHSL1 at MMIO 0x16340000 (irq = 184) is a MSM
[    3.376319] msm_serial_hsl: console setup on port #1
[   11.890784] msm_serial_hsl: detected port #2
[   11.943330] msm_serial_hsl.2: ttyHSL2 at MMIO 0x12490000 (irq = 227) is a MSM
[   12.027241] msm_serial_hsl: driver initialized
[   12.082599] msm_nand_probe: phys addr 0x1ac00000
[   12.135926] msm_nand_probe: dmac 0x3
[   12.178600] msm_nand_probe: allocated dma buffer at ffdfc000, dma_addr 4f794000
[   12.267541] status: 20
[   12.294189] nandid: 1580a12c maker 2c device a1
[   12.348359] ONFI probe : Found an ONFI compliant device MT29F1G08ABBEAH4    ,
[   12.433958] Found a supported NAND device
[   12.481693] NAND Controller ID : 0x4030
[   12.527522] NAND Device ID  : 0x1580a12c
[   12.574414] Buswidth : 8 Bits
[   12.609809] Density  : 128 MByte
[   12.648359] Pagesize : 2048 Bytes
[   12.687941] Erasesize: 131072 Bytes
[   12.729584] Oobsize  : 64 Bytes
[   12.767104] CFG0 Init  : 0xa8d408c0
[   12.808747] CFG1 Init  : 0x0004745c
[   12.850421] ECCBUFCFG  : 0x00000203
[   12.933958] Creating 3 MTD partitions on "msm_nand":
[   12.980912] 0x000000000000-0x000002000000 : "aos0"
[   13.112058] 0x000002000000-0x000004000000 : "aos1"
[   13.231021] 0x000004000000-0x000008000000 : "ubifs"
[   13.424773] m25p80 spi5.0: found mx25u3235f, expected s25fl512s
[   13.483317] m25p80 spi5.0: mx25u3235f (4096 Kbytes)
[   13.582880] Creating 1 MTD partitions on "m25p80":
[   13.627866] 0x000000000000-0x000000400000 : "all"
[   13.686785] UBI: attaching mtd0 to ubi0
[   13.729896] UBI: physical eraseblock size:   131072 bytes (128 KiB)
[   13.804842] UBI: logical eraseblock size:    126976 bytes
[   13.869447] UBI: smallest flash I/O unit:    2048
[   13.925710] UBI: VID header offset:          2048 (aligned 2048)
[   13.997563] UBI: data offset:                4096
[   14.564573] UBI: max. sequence number:       95
[   14.627116] UBI: attached mtd0 to ubi0
[   14.659512] UBI: MTD device name:            "aos0"
[   14.717838] UBI: MTD device size:            32 MiB
[   14.776163] UBI: number of good PEBs:        256
[   14.831365] UBI: number of bad PEBs:         0
[   14.884473] UBI: number of corrupted PEBs:   0
[   14.937613] UBI: max. allowed volumes:       128
[   14.992814] UBI: wear-leveling threshold:    4096
[   15.049078] UBI: number of internal volumes: 1
[   15.102186] UBI: number of user volumes:     1
[   15.155326] UBI: available PEBs:             0
[   15.208466] UBI: total number of reserved PEBs: 256
[   15.266791] UBI: number of PEBs reserved for bad PEB handling: 2
[   15.338675] UBI: max/mean erase counter: 16/1
[   15.390752] UBI: image sequence number:  0
[   15.439768] UBI: background thread "ubi_bgt0d" started, PID 997
[   15.439862] UBI: attaching mtd1 to ubi1
[   15.439862] UBI: physical eraseblock size:   131072 bytes (128 KiB)
[   15.439893] UBI: logical eraseblock size:    126976 bytes
[   15.439893] UBI: smallest flash I/O unit:    2048
[   15.439925] UBI: VID header offset:          2048 (aligned 2048)
[   15.439925] UBI: data offset:                4096
[   16.383848] UBI: max. sequence number:       72
[   16.446110] UBI: attached mtd1 to ubi1
[   16.478506] UBI: MTD device name:            "aos1"
[   16.536801] UBI: MTD device size:            32 MiB
[   16.595157] UBI: number of good PEBs:        256
[   16.650359] UBI: number of bad PEBs:         0
[   16.703467] UBI: number of corrupted PEBs:   0
[   16.756607] UBI: max. allowed volumes:       128
[   16.811808] UBI: wear-leveling threshold:    4096
[   16.868072] UBI: number of internal volumes: 1
[   16.921180] UBI: number of user volumes:     1
[   16.974320] UBI: available PEBs:             0
[   17.027460] UBI: total number of reserved PEBs: 256
[   17.085785] UBI: number of PEBs reserved for bad PEB handling: 2
[   17.157638] UBI: max/mean erase counter: 25/1
[   17.209715] UBI: image sequence number:  0
[   17.258731] UBI: background thread "ubi_bgt1d" started, PID 1000
[   17.258825] UBI: attaching mtd2 to ubi2
[   17.258825] UBI: physical eraseblock size:   131072 bytes (128 KiB)
[   17.258856] UBI: logical eraseblock size:    126976 bytes
[   17.258856] UBI: smallest flash I/O unit:    2048
[   17.258887] UBI: VID header offset:          2048 (aligned 2048)
[   17.258887] UBI: data offset:                4096
[   18.717088] UBI: max. sequence number:       27
[   18.780193] UBI: attached mtd2 to ubi2
[   18.812589] UBI: MTD device name:            "ubifs"
[   18.871946] UBI: MTD device size:            64 MiB
[   18.930271] UBI: number of good PEBs:        512
[   18.985473] UBI: number of bad PEBs:         0
[   19.038612] UBI: number of corrupted PEBs:   0
[   19.091721] UBI: max. allowed volumes:       128
[   19.146954] UBI: wear-leveling threshold:    4096
[   19.203186] UBI: number of internal volumes: 1
[   19.256294] UBI: number of user volumes:     1
[   19.309434] UBI: available PEBs:             0
[   19.362574] UBI: total number of reserved PEBs: 512
[   19.420899] UBI: number of PEBs reserved for bad PEB handling: 5
[   19.492783] UBI: max/mean erase counter: 2/1
[   19.543798] UBI: image sequence number:  -1735857922
[   19.603217] UBI: background thread "ubi_bgt2d" started, PID 1003
[   19.808372] GPIO Bitbanged MDIO: probed
[   19.844142] ipq-dwc3 ipq-dwc3.0: unable to read platform data num of dbm eps
[   20.029209] ipq-dwc3 ipq-dwc3.1: unable to read platform data num of dbm eps
[   20.204529] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   20.270384] msm_hsusb_host msm_hsusb_host: unable to find transceiver
[   20.349390] xhci-hcd xhci-hcd.0: xHCI Host Controller
[   20.407903] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 1
[   20.494345] xhci-hcd xhci-hcd.0: irq 142, io mem 0x11000000
[   20.561137] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   20.642143] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   20.728584] usb usb1: Product: xHCI Host Controller
[   20.786910] usb usb1: Manufacturer: Linux 3.4.103 xhci-hcd
[   20.852546] usb usb1: SerialNumber: xhci-hcd.0
[   20.906622] hub 1-0:1.0: USB hub found
[   20.950640] hub 1-0:1.0: 1 port detected
[   20.997875] xhci-hcd xhci-hcd.0: xHCI Host Controller
[   21.057825] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 2
[   21.144361] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[   21.225492] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   21.311902] usb usb2: Product: xHCI Host Controller
[   21.370259] usb usb2: Manufacturer: Linux 3.4.103 xhci-hcd
[   21.435863] usb usb2: SerialNumber: xhci-hcd.0
[   21.489846] hub 2-0:1.0: USB hub found
[   21.533833] hub 2-0:1.0: 1 port detected
[   21.581193] xhci-hcd xhci-hcd.1: xHCI Host Controller
[   21.641174] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 3
[   21.727647] xhci-hcd xhci-hcd.1: irq 237, io mem 0x10000000
[   21.794470] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[   21.875476] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   21.961918] usb usb3: Product: xHCI Host Controller
[   22.020243] usb usb3: Manufacturer: Linux 3.4.103 xhci-hcd
[   22.085879] usb usb3: SerialNumber: xhci-hcd.1
[   22.139862] hub 3-0:1.0: USB hub found
[   22.183817] hub 3-0:1.0: 1 port detected
[   22.231146] xhci-hcd xhci-hcd.1: xHCI Host Controller
[   22.291159] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 4
[   22.377725] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[   22.458856] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   22.545267] usb usb4: Product: xHCI Host Controller
[   22.603592] usb usb4: Manufacturer: Linux 3.4.103 xhci-hcd
[   22.669228] usb usb4: SerialNumber: xhci-hcd.1
[   22.723211] hub 4-0:1.0: USB hub found
[   22.767166] hub 4-0:1.0: 1 port detected
[   22.814714] i2c /dev entries driver
[   22.856263] Found AT97SC3203 on i2c-gpio0
[   22.908216] cpuidle: using governor ladder
[   22.952577] cpuidle: using governor menu
[   22.999500] usb 3-1: new full-speed USB device number 2 using xhci-hcd
[   23.077819] usb 3-1: Device not responding to set address.
[   23.146422] NET: Registered protocol family 10
[   23.197656] NET: Registered protocol family 17
[   23.249453] 8021q: 802.1Q VLAN Support v1.8
[   23.299593] VFP support v0.3: implementor 51 architecture 64 part 4d variant 2 rev 0
[   23.392252] Registering SWP/SWPB emulation handler
[   23.392283] usb 3-1: Device not responding to set address.
[   23.515057] clock_late_init: Removing enables held for handed-off clocks
[   23.598000] usb 3-1: device not accepting address 2, error -71
[   23.670353] no pmic restart interrupt specified
[   23.720805] msm_cache_dump_probe: could not register L2 buffer ret = -22.
[   23.897969] usb 3-1: new full-speed USB device number 3 using xhci-hcd
[   23.963698] usb 3-1: Device not responding to set address.
[   24.238019] usb 3-1: Device not responding to set address.▒[   24.407997] Freeing init memory: 5128K
[   24.440362]
[   24.440362] Starting Kernel SHA1 KAT ...
[   24.497969] usb 3-1: device not accepting address 3, error -71
[   24.574726] Completed Kernel SHA1 KAT
[   24.619525] Starting Kernel HMAC-SHA1 KAT ...Starting Kernel DES KAT ...Completed Kernel DES KAT
[   24.725804] Starting Kernel AES KAT ...Completed Kernel AES KAT
[   24.769540]
[   24.815401] Starting Kernel AESGCM KAT ...Completed Kernel HMAC-SHA1 KAT
[   24.867947] usb 3-1: new full-speed USB device number 4 using xhci-hcd
[   24.974726] usb 3-1: Device not responding to set address.
[   25.067635] Completed Kernel AESGCM KAT
[   25.248047] usb 3-1: Device not responding to set address.
[   25.302467] UBIFS: recovery needed
[   25.507966] usb 3-1: device not accepting address 4, error -71
[   25.565354] UBIFS: recovery completed
[   25.609059] UBIFS: mounted UBI device 2, volume 0, name "ubifs"
[   25.679881] UBIFS: file system size:   62726144 bytes (61256 KiB, 59 MiB, 494 LEBs)
[   25.771540] UBIFS: journal size:       3174400 bytes (3100 KiB, 3 MiB, 25 LEBs)
[   25.797969] usb 3-1: new full-speed USB device number 5 using xhci-hcd
[   25.798063] usb 3-1: Device not responding to set address.
[   26.002811] UBIFS: media format:       w4/r0 (latest is w4/r0)
[   26.072602] UBIFS: default compressor: lzo
[   26.072727] usb 3-1: Device not responding to set address.
[   26.187191] UBIFS: reserved for root:  2962710 bytes (2893 KiB)
[   26.277944] usb 3-1: device not accepting address 5, error -71
[   26.335332] hub 3-0:1.0: unable to enumerate USB device on port 1
AP-type has_ble_support: .
Domain Name: arubanetworks.com
No panic info available
[   29.420462] PPP generic driver version 2.4.2
[   29.467291] **********************************************************
[   29.535114] * Driver    :NSS GMAC Driver for RTL v(3.72a)
[   29.599687] * Version   :1.0
[   29.634051] * Copyright :Copyright (c) 2013-2014 The Linux Foundation. All rights reserved.
[   29.734051] **********************************************************nss_driver - fw of size 325440  bytes copied to load addr: 40000000, nss_id : 0
[   29.924023] nss_driver - Turbo Support 1
[   29.959575] bf02d1d0: NSS Shaping is enabled, handler id: 0
[   30.029178] nss_driver - fw of size 186688  bytes copied to load addr: 40800000, nss_id : 1
[   30.136582] Error - Duplicate Interface CB Registered for interface 75
[   30.203248] Error - Duplicate Interface CB Registered for interface 78
dev.nss.n2hcfg.n2h_empty_pool_buf_core0 = 2048
dev.nss.n2hcfg.n2h_empty_pool_buf_core1 = 2048
Ethernet port 1 mode: active-standby
[   31.464885] bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
[   31.542205] bonding: MII link monitoring set to 400 ms
[   31.615245] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   31.674101] ADDRCONF(NETDEV_UP): bond0: link is not ready
[   31.752827] bonding: bond0: enslaving eth0 as a backup interface with a down link.
[   31.871415] bonding: bond0: enslaving eth1 as a backup interface with a down link.
[   31.984379] drvlog_mod: module license 'Proprietary' taints kernel.
[   32.046954] Disabling lock debugging due to kernel taint
[   32.134020] AP xml model 89, num_radios 2 (jiffies 4294940508)
[   32.191471] init_asap_mod: installation:0
[   32.239425] radio 0: band 1 ant 0 max_ssid 16
[   32.291440] radio 1: band 0 ant 0 max_ssid 16
[   32.343548] ethernet_device_event: dev eth0 is up
Starting watchdog process...
Getting an IP address...
[   35.277944] Kernel watchdog refresh ended on core 0.
[   35.337956] Kernel watchdog refresh ended on core 1.
[   35.842143] eth0: 1000Mbps FullDuplex
[   36.067978] bonding: bond0: link status definitely up for interface eth0, 1000 Mbps full duplex.
[   36.162824] bonding: bond0: making interface eth0 the new active one.
[   36.240174] bonding: bond0: first active interface up!
[   36.301499] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
192.168.0.100 255.255.255.0 192.168.0.1
Running ADP...Done. Master is 192.168.0.201
[   39.849515] ath_hal: 0.9.17.1 (AR5416, AR9380, WRITE_EEPROM, 11D)
[   39.918525] ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
[   40.029709] ath_dfs: Version 2.0.0
[   40.029709] Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
[   40.162949] ath_spectral: Version 2.0.0
[   40.162949] Copyright (c) 2005-2009 Atheros Communications, Inc. All Rights Reserved
[   40.293345] SPECTRAL module built on Apr 30 2015 14:36:41
[   40.368728] ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
[   40.480912] ath_pci:  (Atheros/multi-bss)
[   40.516651] PCI: enabling device 0000:01:00.0 (0140 -> 0142)
[   40.584536] ath_pci 0000:01:00.0: ath DEBUG: sc=0xce0c1200
[   41.575788] Shutting down eth1 due to insufficient POE voltage [power profile 2]
[   41.652764] Disabling USB power
************************************************** TRUNCATED************************************************
All help appreciated
Adrian
Re: Master Discovered but AP's not showing in controller
Try running "show log system 50" on the controller to see if they've connected.
Tim Cappalli | Aruba Security
Thaks for the help.
Something aint happy see below
Jun 5 17:54:44 :305059:  <WARN> |stm|  Version (null) is not compatible with AP 84:d4:7e:ce:fa:ec with type AP-UNKNOWN, mac 84:d4:7e:ce:fa:ec
Jun 5 17:54:44 :399803:  <ERRS> |stm|  An internal system error has occurred at file sapm_ap_mgmt.c function sapm_get_img_build_version_str line 10238 error stat /mswitch/sap/ipq806x.ari failed: No such file or directory.
Jun 5 17:54:44 :305059:  <WARN> |stm|  Version (null) is not compatible with AP 40:e3:d6:ce:61:fa with type AP-UNKNOWN, mac 40:e3:d6:ce:61:fa
Upgrade your controller to the latest 6.4.4 build.
Im having trouble getting the software. My support account is not working properly
Adrian
When I logon too support it says UserWithNoRole
Ive registered and entered serial but still no proper access.
Adrian
Please email support@arubanetworks.com for assistance with your account.
Thank you so much for your help
Regards
Adrian
