Master / Standby controller failover testing
In our wireless enviroment we have a wireless controller in each of our 2 major data centres.  One is active master, whilst the other is a standby master.
I've been asked if it possible to reverse the roles every couple of months for complience reasons.  Is it as easy as changing the piority on the vrrp?
Cheers
Paul
Re: Master / Standby controller failover testing
Yes, as long as preemption is enabled.
Zach Jennings
