Max AMP API calls/second
Periodically I need to pull the channel utilization information for all APs (~3000 APs), for now only a max of 3 concurrent API calls are handled by the AMP API. If I increase the request count the API response is really slow.
How do I increase the API request/second limit for an AMP/ controller? Is there a configuration setting for this?
