Max AMP User Idle Timeout - @^#%$%^!!!
     Is there any way to overcome the Max AMP User Idle Timeout of 240 minutes?
Re: Max AMP User Idle Timeout - @^#%$%^!!!
Yes you can disable timeout for a user with the below steps.
1. Login to AMP with admin privilages
2. Go to AMP Setup->Roles
3. Click on edit for the required user
4. Select 'Allow user to disable timeout:' to 'Yes'.
5. Now go to Home->User Info and select 'Disable Timeout:' to 'Yes'.
Wow, thank you :)
I like a lot of things about AMP, but this isn't one of them. They've
took something straightforward and turned it into an obstacle course...
To change the max idle value allowed for Idle Timeout is on AMP Setup -> Authentication tab -> Login Configuration box -> Max AMP User Idle Timeout.
Note: This doesn't define the user's timeout value, this is just the ceiling limit for the maximum time that a user can set as their idle timeout value.
Then on Home -> User Info tab -> Display Preferences box -> Idle Timeout value can be set within the range.
Though if the timeout range is really large, then you may as well just disable the timeout.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
