Max EIRP by Country Code
I need to get the max EIRP by country Code
i traid this commad , but it did not work with ArubaOS 6.4.4.4
show ap allowed-max-EIRP ap-name <AP> country-code <country>
any idea ?
Regards
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: Max EIRP by Country Code
What is the exact command you are typing?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
show ap allowed-channels ap-name <AP> country-code <country>   (works)
show ap allowed-max-EIRP ap-name <AP> country-code <country>  (do not work)
i need to know witch channel and witch max eirp level are allowed by country code
Raouf CHAHBOUNE
That command only works if the specific AP model is connected to the controller runnign the country code you need to see. If you provide a list of countries you need, someone might be able to run them down. Otherwise you would need to look up each country's regulatory bodies, as it's not something we publish.
Jerrod Howard
where can i get the infomration
Raouf CHAHBOUNE
You can run the following command from the CLI to show maximum allowed EIRP values for each channel: show ap allowed-max-EIRP ap-name country-code e.g. #show ap allowed-max-EIRP ap-name country-code GB Max EIRP setting for Country Code GB Country United Kingdom and AP type AP-105
You can either put an AP on your controller and assuming you have a ROW controller, change the country code in the system profile and move the AP around and then run the command, or you can email your local Aruba sales engineer with a list of countries and they can request, or you can open a TAC case with your request and they can look it up for you.
Jerrod Howard
kdisc, what version of AOS are you on? That doesn't work at least for AOS 6.5?
Edit: Kdisc, you may have a ROW controller, that might work. For US locked it won't. :)
Jerrod Howard
http://www.arubanetworks.com/techdocs/ArubaOS_61/ArubaOS_61_CLI/showap.htm
https://community.arubanetworks.com/t5/tkb/articleprintpage/tkb-id/ControllerBasedWLANs/article-id/1680
