Max amount of profiles and AP-Groups
Hi all,
I have a client with 2 WLC 7210 in his DC. He plans now to deploy APs in all its Branch Office.
As the configuration may be different in each branch, I want to be sure that he can create enough AP-Groups and other Profiles (VAP, SSID, AAA) if necessary.
I couldn't find any limitation in the Datasheet.
Did somebody knows how many AP-Groups and Profiles can be created or where I can find the information?
Thanks and Kind Regards,
Nicolas.
Re: Max amount of profiles and AP-Groups
There is no hard limit.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Hi Colin,
So I can create about 100 AP-groups on my 7210 Controllers without any trouble?
Yes.  Your biggest problem would be managing them in any coherent fashion.
