MVP
Max number of associated clients per radio 255
While I understand that you want to design your network so that tyou'll never get even near that 255 clients per radio, you'lle always have customers that ask the question anyway.
So just so I can give the correct answer (while convincing them of the silliness of the question).. what would happen?
Is this a hard limit, the AP running out of registers or something. Or is that simply a limit the technical marketeers imagined to stop clients from actualy trying to load their APs with such numbers?
Koen (ACMX #351 | ACDX #547 | ACCP)
Re: Max number of associated clients per radio 255
You can make up any story that you like and pass it onto us.  The best story we receive we will put it in the user manual.  :)
MVP
Hahaha, I think I'll just use that! :D
