Super Contributor II
Maximum Number of Concurrent Management Users
Dear Friends,
How many concurrent users can access the controller via GUI by using single user name and password.
let suppose we have only one management with username: admin and password: admin123. how many users can connect using this username and password at the same time.
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
Re: Maximum Number of Concurrent Management Users
It might depend on the type of controller you have but you can determine by executing the following command from your controller :
This is the output from an M3 controller and the default is 25 concurrent web sessions
(aruba-controller) #show web-server
Web Server Configuration
Parameter Value
Cipher Suite Strength high
SSL/TLS Protocol Config sslv3 tlsv1
Switch Certificate default
Captive Portal Certificate default
Management user's WebUI access method username/password
User session timeout <30-3600> (seconds) 900
Maximum supported concurrent clients <25-400> 25
But for the CLI/SSH session the maximum I believe it is 5.
Hope this helps
If you find the post helpful please Kudo the post
Thank you
Victor Fabian
Lead Mobility Architect @WEI
