Maximum Number of Connection per User Account
Hi Guys,
Is there an option on Aruba Mobility Controller where I can set a number maximum connection per User Account (802.1x). The client would like to limit the usage of 2 devices per user account.
Your help will very much appreciated. Thank you in advance!
Ryan
Re: Maximum Number of Connection per User Account
You can do this with ClearPass but I don't believe you can with just a controller.
Cheers
James
ryca11 wrote:
Hi Guys,
Ryan
You would need a Policy Engine (Radius Server like ClearPass) that keeps track of clients via radius accounting to limit this.  The controller by itself cannot do that with 802.1x clients.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thank you. I also thought there's no option using only the mobility controller. Thank you for the response.
Yeah. I also thought I need a NAC device to do it. I have scan all the authentication button and I have found nothing. Thanks!
