Maximum Request Retries
How you define Maximum Request Retries ?
What is the default value ?
Frequent Contributor II
Re: Maximum Request Retries
for what?
for papi tunnel?
PAPI heartbeat (default value is 10 retries, 60 second interval, 10 request retries)
ap system-profile <system prof name> max-request-retries <maximum number of retries>
check this doc, it's old but very nice --> http://community.arubanetworks.com/aruba/attachments/aruba/84/106/1/Troubleshooting+Cheat+Sheet-.pdf
Andrea Consadori
ACMP 5.0 and 6.3
