Maximum ceiling height for AP-225
Is there a maximum ceiling height for the AP-225 at which point you would consider deploying an alternate AP with an external, directional antenna?
Re: Maximum ceiling height for AP-225
I've seen IAP-225s work just fine at heights up to 30 feet.
How are high are you thinking of going?
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACMP
[If you found my post helpful, please give kudos!]
