Hi there,
I am checking the IAP-325 datasheet and I see the following:
• Maximum (aggregate, conducted total) transmit power
(limited by local regulatory requirements):
--2.4 GHz band: +24 dBm (18 dBm per chain)
--5 GHz band: +24 dBm (18 dBm per chain)
This IAP is a 4x4 MIMO, so it has 4 transmit chains. If each one has 18 dBm transmit power, it would have a maximum transmit power of 18+18+18+18 = 72 dBm, which is a huge power and doesn't match that of the datasheet which is 24 dBm. What am I doing wrong?
Julián
