Regular Contributor I
Mesh Link
I have a question about MESH links. Please see the screenshots attached.
Looking at one mesh link i can see tx/rx link at 130/130 and the other one says 65/65 does this mean one of my antennas is not working?
Re: Mesh Link
Anyone?
Re: Mesh Link
That value will vary depending on the Quality of the Mesh link
Just like a typical wireless client connection
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Re: Mesh Link
There could also be varying degrees of interference, noise floors, etc. What antennas/link distance, etc is there on each side?
One other thing, those numbers are not an immediate snapshot and are traffic dependent. You could look within the CLI guide to pull more instantaneous metrics from the mesh link, but ultimately are you seeing bi-directional speed variances or is it stable and consistent?
Jerrod Howard
