Contributor II
Mesh OS
Im plannig to deploy 8 MSR2000 to make 4 bridge links to outdoor buildings.
My question is about the use of Mesh OS , I need to buy one MeshOS licences per MSR ?, I dont need the MeshOS? or only need one MeshOS to all of them? The Idea is to have One mesh portal and one mesh point.
Thanks in advance.
Re: Mesh OS
Hi Ericky,
MSRs are autonomous APs.   There is no controller.   So you do not have to purchase any separate license.
The hardware ships with the software pre-loaded.
You do need to purchase software maintance if you wish to have access to bug fixes, new features, etc.
Re: Mesh OS
More relevant info - regarding the product line itself and it great capabilities & specs , u may find in the following link:
Hope it will answer your questions.
Contributor II
Re: Mesh OS
Oh Thanks. That's great.
