Also, if you have a mix of mesh and non-mesh APs, the next easiest thing to do is to create a new VAP with the same AAA, SSID, etc settings but call it <existingvapname>-mesh or whatever, and apply that X-mesh VAP to JUST your mesh AP group. Then as you make changes to the AAA or SSID profiles, you don't have to make them in two places.
That said, in MOST cases, you want separate mesh SSID and non-MESH (think indoor) SSIDs, as you may not want to remove the lower basic rates outdoor that you would indoor (or vice versa). So for a product environment, you may want your normal <x> SSID and VAP profiles, and your <x>-mesh SSID and VAP profiles.
