The "Mesh Cluster Profile" has an RF parameter that determines if mesh will occur on the "a" or "g" band. Please consult the documentation on support.arubanetworks.com for ArubaOS and inspect the Mesh chapter for detailed configuration steps.
The AP70 has 4 connectors: two dedicated to the "a" antennas that you could use and two for the "g" antennas. When you provision the access point under Configuration> Wireless> AP Installation, you can configure the AP to use the external antennas, as well as the dB for each antenna. You cannot use one radio for internal and one as external: They both have to be the same.
