Occasional Contributor I
Mesh WLAN
In what case is it absolutely necessary to deploy a mesh network instead of a regular mesh?
Re: Mesh WLAN
What is the difference between regular mesh and a mesh network?
Colin Joseph
Aruba Customer Engineering
Re: Mesh WLAN
I was recently faced with the same question/issue.  For me the difference is that "regular mesh" is part of ArubaOS and the controller environment, while "mesh network" is part of the AirMesh product line running MeshOS.  We have a policy that all vlans are tagged on trunk links and that was not possible with ArubaOS (the management vlan had to be untagged). We are now using the MST200 for point to point bridging.
I guess that the question for Verotiana is, what are you trying to accomplish?
Re: Mesh WLAN
Ok, typo, my mistake.
I meant "In what case is it absolutely necessary to deploy a mesh network instead of a regular wireless network?"
Frequent Contributor II
Re: Mesh WLAN
Mesh networks are usually deployed outdoors, where the uplink of an accesspoint is not wired but wireless.
ACMX#255 | ACDX#742 | ACCX#746 | AMFX#25 | ACMP | ACCP | AWMP
www.securelink.nl
Re: Mesh WLAN
Re: Mesh WLAN
Not sure I follow, but anything client to AP is 'wireless access / wireless network', anything AP to AP could be 'mesh / wireless bridging'.
Jerrod Howard
