Frequent Contributor II
Mesh & Covrage on Same AP175
If i want AP-175 tpo provide Coverage + Mesh connectivity , can i use only 2.4GHz antenna to provide both ?
Re: Mesh & Covrage on Same AP175
is it doable ?
Yes you can.  The mesh cluster profile determines what band you using to mesh.  The Virtual AP determines what band(s) you broadcast the WLAN on.
