Hi
I have an Aruba 620 controler with 2 AP92's with external antenna's configured as a mesh link the link somtimes is weejks stable and then it keeps on rebooting for a couple of days, I followed the aruba white papers for setting up the link al settings are standard.
Here is the AP-debug output,
Nov 29 04:23:25 KERNEL(NRAAP0003-PORTAL@10.200.11.245): RESTARTING ALL TX
Nov 29 04:23:34 KERNEL(NRAAP0002-POINT@(none)): AG7240: enet unit:0 is up...
Nov 29 04:23:34 KERNEL(NRAAP0002-POINT@(none)): RGMii 1000Mbps full duplex
Nov 29 04:23:34 KERNEL(NRAAP0002-POINT@(none)): AG7240: done cfg2 0x7235 ifctl 0x0 miictrl
Nov 29 04:28:03 KERNEL(NRAAP0002-POINT@(none)): AG7240: bad skb, len 1522
Nov 29 04:28:03 KERNEL(NRAAP0002-POINT@(none)): AG7240: dropping skb 81393360
Nov 29 04:28:03 KERNEL(NRAAP0002-POINT@(none)): AG7240: dropping skb 82890620
Nov 29 04:37:10 KERNEL(NRAAP0003-PORTAL@10.200.11.245): AG7240: bad skb, len 1522
Nov 29 04:37:10 KERNEL(NRAAP0003-PORTAL@10.200.11.245): AG7240: dropping skb 83ea9080
Nov 29 04:46:30 KERNEL(NRAAP0003-PORTAL@10.200.11.245): AG7240: bad skb, len 1522
Nov 29 04:46:30 KERNEL(NRAAP0003-PORTAL@10.200.11.245): AG7240: dropping skb 813bc260
Nov 29 04:46:30 KERNEL(NRAAP0003-PORTAL@10.200.11.245): AG7240: dropping skb 82aab900
Nov 29 04:53:36 KERNEL(NRAAP0003-PORTAL@10.200.11.245): AG7240: bad skb, len 1522
Nov 29 04:53:36 KERNEL(NRAAP0003-PORTAL@10.200.11.245): AG7240: dropping skb 824070e0
Nov 29 04:53:36 KERNEL(NRAAP0003-PORTAL@10.200.11.245): AG7240: dropping skb 813fd4e0
Nov 29 04:55:42 KERNEL(NRAAP0003-PORTAL@10.200.11.245): RESTARTING ALL TX
Nov 29 04:55:48 KERNEL(NRAAP0002-POINT@(none)): ATHRSF1_PHY: Port 0, Neg Success
Nov 29 04:55:48 KERNEL(NRAAP0002-POINT@(none)): ATHRSF1_PHY: unit 0 phy addr 0 Not enabling interrupts in AR7242 yet...
Nov 29 04:55:52 KERNEL(NRAAP0002-POINT@(none)): AG7240: enet unit:0 is up...
Nov 29 04:55:52 KERNEL(NRAAP0002-POINT@(none)): RGMii 1000Mbps full duplex
Nov 29 04:55:52 KERNEL(NRAAP0002-POINT@(none)): AG7240: done cfg2 0x7235 ifctl 0x0 miictrl
Nov 29 05:14:27 KERNEL(NRAAP0003-PORTAL@10.200.11.245): AG7240: bad skb, len 1522
Nov 29 05:14:27 KERNEL(NRAAP0003-PORTAL@10.200.11.245): AG7240: dropping skb 83cd90c0
Nov 29 05:14:27 KERNEL(NRAAP0003-PORTAL@10.200.11.245): AG7240: dropping skb 83539720
Nov 29 05:29:05 KERNEL(NRAAP0003-PORTAL@10.200.11.245): RESTARTING ALL TX
Nov 29 05:29:10 KERNEL(NRAAP0002-POINT@(none)): vap aruba000 vlan is 0. fwd-mode:0 mesh
Nov 29 05:29:10 KERNEL(NRAAP0002-POINT@(none)): ag7240_ring_alloc Allocated 640 at 0x8122bc00
Nov 29 05:29:10 KERNEL(NRAAP0002-POINT@(none)): ag7240_ring_alloc Allocated 4032 at 0x828d1000
Nov 29 05:29:10 KERNEL(NRAAP0002-POINT@(none)): Virian MDC CFG Value ==> 4
Nov 29 05:29:10 KERNEL(NRAAP0002-POINT@(none)): Setting PHY...
Nov 29 05:29:10 KERNEL(NRAAP0002-POINT@(none)): ATHRSF1_PHY: Port 0, Neg Success
Nov 29 05:29:10 KERNEL(NRAAP0002-POINT@(none)): ATHRSF1_PHY: unit 0 phy addr 0 Not enabling interrupts in AR7242 yet...
Nov 29 05:29:14 KERNEL(NRAAP0002-POINT@(none)): AG7240: enet unit:0 is up...
Nov 29 05:29:14 KERNEL(NRAAP0002-POINT@(none)): RGMii 1000Mbps full duplex
Nov 29 05:29:14 KERNEL(NRAAP0002-POINT@(none)): AG7240: done cfg2 0x7235 ifctl 0x0 miictrl
Nov 29 05:32:04 KERNEL(NRAAP0002-POINT@(none)): AG7240: bad skb, len 1522
Nov 29 05:32:04 KERNEL(NRAAP0002-POINT@(none)): AG7240: dropping skb 82853340
Nov 29 05:32:04 KERNEL(NRAAP0002-POINT@(none)): AG7240: dropping skb 81394440
Nov 29 05:33:13 KERNEL(NRAAP0003-PORTAL@10.200.11.245): AG7240: bad skb, len 1522
Nov 29 05:33:13 KERNEL(NRAAP0003-PORTAL@10.200.11.245): AG7240: dropping skb 82ef3320
Nov 29 05:55:23 KERNEL(NRAAP0003-PORTAL@10.200.11.245): AG7240: bad skb, len 1522
Nov 29 05:55:23 KERNEL(NRAAP0003-PORTAL@10.200.11.245): AG7240: dropping skb 82ef1ae0
Nov 29 06:03:24 KERNEL(NRAAP0003-PORTAL@10.200.11.245): RESTARTING ALL TX
Nov 29 06:03:33 KERNEL(NRAAP0002-POINT@(none)): AG7240: enet unit:0 is up...
Nov 29 06:03:33 KERNEL(NRAAP0002-POINT@(none)): RGMii 1000Mbps full duplex
Nov 29 06:03:33 KERNEL(NRAAP0002-POINT@(none)): AG7240: done cfg2 0x7235 ifctl 0x0 miictrl
please does somebody have a tip to solve this?
Kind regards,
Reinier van Haeften
