Mesh point not working
Hi, I created a mesh cluster profile. Provisioned a ap as a cluster portal, and provisioned a second ap as a mesh point. Both ap's are using the mesh cluster profile. My problems is that just after the mesh point ap is provisioned it does not get an address and the green light just blinks?
jason
Aruba
Re: Mesh point not working
Hi Jason,
Long time no chat.
What version of AOS are you using ?
Are you using encryption or open-system on the mesh link ?
I assume the two devices are  on the table top at present ?
hi, we are using 6.1.3.2 opensystem.
Thx jason
Problem solved. The ap's had to be in the same ap group as the cluster profile.
