MVP
Mesh points dot11a radio channel reflected as 0 on dashboard!
I am running with code 6.5.0.2 on Aruba7240XM.
The Mesh backhaul is on 5 ghz radio. When I monitor the status of mesh points on dashboard, there are few of them against which the channel is reflected as 0, PFA. What do it signify?
From the cli, could see appropriate channels against them though:
(WLC_0002) #show ap radio-summary dot11a | include XXX1
XXX1          AP-GRP1              274      172.25.44.142  5     MP::36       15/20         -94/55/12  6/4/5/6/5/8       24/25/24/25/26/23  2/1/1/2/1/2
(WLC_0002) #show ap radio-summary dot11a | include XXX2
XXX2          AP-GRP1              277      172.25.44.132  5     MP::36    15/28.5       -97/51/12  5/3/4/5/4/6       24/24/25/24/22/23  1/1/1/1/1/1
(WLC_0002) #show ap radio-summary dot11a | include XXX3
XXX3          AP-GRP1              277      172.25.44.222  5     MP::36    15/28.5       -97/56/10  7/9/11/13/10/14    21/20/21/18/20/18  2/2/2/2/2/2
Re: Mesh points dot11a radio channel reflected as 0 on dashboard!
I would upgrade to 6.5.0.4 and see if you still see the same symptoms.  Many bugs were fixed in 6.5.0.3 and 6.5.0.4.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
