Frequent Contributor II
Mini USB console on OSX
I decided to try out the new Mini-USB console cable for the 7010 controllers but after installing the driver I have been unable to see the device in my terminal emulator.
Anyone succesfully done this?  I'm using SecureCRT.
Re: Mini USB console on OSX
Are you running Yosemite?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Yes
Sent from my iPhone
Try this file (change the extension to .zip), and see if it works.
