Contributor II
Missing APs licenses
Hi.
When I try the command  "show license"
The license table is incomplete, because my key license for access point  don't show up.
My AOS version is 5.0.3.3 this is happening in a 3200 and  a 3600 controller.
When I run a "show license limits" the limits are Ok.
How can I show my missing license.
Thanks in advance.
Retired Employee
Re: Missing APs licenses
Does the controller has inbuilt licenses for those APs?
Can you post the output of command "show inventory"
HT
Contributor II
Sorry I don't have access to the controller at the moment
But I know that the 3600 controller have 4 inbuild licenses.
Retired Employee
How many AP license mismatch do you see on the controller? It should be equal to
Inbuilt AP license = license limit - installed license
The Inventory should have the model number as 3200-x / 3600-y where x,y = inbuilt AP license count
HT
Contributor II
Sorry but my customer is so busy , but finally here is the output for inventory.
Supervisor Card slot            : 0
System Serial#                  : AC000xxxx
SC      Assembly#               : 2010031B (Rev:04.01)
SC      Serial#                 : F0083xxxx (Date:07/11/08)
SC      Model#                  : Aruba3600
It says only Aruba 3600 then this controller doesn't have inbuilt licenses?
And where may be it the missing licences.?
thanks in advance.
You want the output of "show keys"
A controller can only have AP licenses built in; not any of the others.
Show keys will show you what you are working with.
