Mobile SSID is not getting an IP
Good evevning ,
We have a ssid called Mobile Devices , previously it was working without any issue . But now users are reported that they cant access the internet .As investigated users are able to connect but instead of 17.16.X.X ip they have got 0.0.0.0 . I hope 172.16 .X.X is the default IP and it will be assiged by VC (Virtual controller) . Can any one please help me on this ?
Thank you
Re: Mobile SSID is not getting an IP
If you want the Virtual Controller to give out IPs and NAT traffic ->
Under the VLAN settings of the network, make sure it's set to "Virtual Controller Assigned" if you want the VC to hand out IP addresses. Then go to top right options, click More and go to DHCP Server. Under the default (I think top section) make sure you have the proper network range and information you want to assign. The virtual controller than becomes the gateway for all clients and effectively NATs traffic.
Michael Haring
If my answer is helpful, a Kudos is always appreciated!
In my setup , IP address has been allocated by VC for the mobile SSID .
The problem is , usually 172.31.x.x ip will be assigned to the device .But now its showing as 0.0.0.0 in device end instead of 172.31.x.x . This issue will be fixed after rebooting the AP / VC .
 Can any one tell me , why this issue happennig and how can we fix this issue .
Thank  you
Jarvis
What version of IAP are you running?
How many devices do you have connecting to that SSID? What size is the subnet? Could it be running out of leases?
If a device is getting 0.0.0.0 that sounds like it just didn't get an IP address yet. You should try running wireshark on a device and connect it to the mobile SSID and watch the DHCP packets, see if your getting an offer from the VC and if your device accepts it.
Michael Haring
