Mobility Controller 3200 captive portal with social login
Is it possible to configure captive portal with social login for Guest access with Mobility Controller 3200? How?
Re: Mobility Controller 3200 captive portal with social login
You would need an external auth service such as Clearpass to achieve this. Using the inbuilt Captive Portal you can only do username/email login.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Ok thanks. Also Aruba Central could act as external auth service and manage the Mobility Controller 3200?
Hey, i'm afraid it can't.
