Mobility Controller Firewall
Hi All,
Is there any feature which can which we can implement to control Wired Access with Mobility Controller?
If Yes, then which feature is been used in Mobility Controller and Access Switch?
Prashant
RE: Mobility Controller Firewall
You can control the wired access with the firewall function of the WLAN controller.
Then which feature is used in access switch to make it happened?
Prashant
Re: Mobility Controller Firewall
Take a look at the ClearPass Solution Guide for Wired Policy Enforcement.
Tim Cappalli | Aruba Security
