Contributor II
Mobility Controller RAP IPSec tunnel
Could someone explain how is IPSec tunnel between controller and RAP formed, what are the parameters we can change, as well as the role of PSK vs certificates in tunnel creation? Thanks in advance.
AlanFord
Kind regards,
AlanFord
Re: Mobility Controller RAP IPSec tunnel
Every AP is issued a factory certificate during manufacturing. This cert is used to build the IPSec tunnel. When you whitelist the RAP on the conttoller, you're essentially whitelisting the cert.
Custom certs can be loaded onto the AP for use with IPSec but it's not a common deployment.
Tim Cappalli | Aruba Security
Contributor II
Thanks Tim, appreciated.
AlanFord
Kind regards,
AlanFord
Contributor II
Tim,
One more question. Does factory certificate ever expire, or is that not important once tunnel is established? Thanks.
AlanFord
Kind regards,
AlanFord
I believe it's a 20 year cert, but don't quote me on that.
