- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Mobility Master Aruba 8.0 and AP registration?
03-22-2018 09:35 PM
Hi Guys,
I want to move from Master/Backup Master (WLC1-Master <=> WLC2-Backup) topology running on WLC 70xx besause they do not support AP point termination starting from 8.0 release (https://community.arubanetworks.com/t5/tkb/articleprintpage/tkb-id/ControllerBasedWLANs/article-id/2740). But, I have only one set of centralized licenses on WLC1.
Could I migrate to WLC1-Local <=> WLC2-Local and still have centralized licensing? Or could I disable Mobility Master?
Cheers,
Alex.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Mobility Master Aruba 8.0 and AP registration?
03-23-2018 04:34 AM
For the AP registration configure VRRP for your two controllers and you can point your Aruba-master to that VIP or DHCP option 43
If your controllers are clustered then the AP will only use the VRRP VIP using the initial setup and after it is provisioned the AP will use the node list all your controllers in the cluster
Pardon typos sent from Mobile
Victor Fabian
Lead Mobility Architect @WEI
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
a month ago - last edited a month ago
Hi Victor,
Thank you your response. If I understand everything correctly, there is no real redundancy with 2 controllers (the setup I have) because they will not register on MM when one controller fails -> such setup does not make sense. Is it correct?
Thank you.
P.S.
I created small lab setup breaking up existing topology to 2 masters. When I use 8.0.0.0 - APs are able to register. When I update to something higher than 8.0.0.0 , there is a message "MM doesn't support AP redirect or termination"
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
a month ago
Victor Fabian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
a month ago
I have 2 WLC 7010 running Master/Backup Master vrrp setup. ArubaOS Version 8.0.0.0.
When I move to something higher than 8.0.0.0, AP registration stops working with the error I put in the last message.
Ideally, I'd like to have the same setup, but only want to upgrade software.
Cheers,
Alex.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
