Occasional Contributor I
Mobility Master Hardware Appliance Mgmt Interface
Hi Airheads
I'm speccing out a solution for someone who wants to use a hardware appliance for his two mobility masters but it's only a two controller deployment currently so we'd rather use the management port only instead of purchasing extra SFPs (definitely don't require 10Gb, that's for sure).
Is the mgmt port usable? Can the controllers use that port to join the domain?
Thanks!
