Mobility Master L3 Redundacy
Hi All,
Aruba newbie so hope this isnt a dumb question.
I have 2 physical MM devices destined for different datacentres/subnets.
L3 redundancy setup and databases syncing.
What 'resilient' IP should I point Managed Devices/MC's to, as there is no VRRP instance?
Do I add a secondary IP after full-setup?
IPSEC SA (V2) Active Session Information
Initiator IP                              Responder IP
(WOR-MM-01) [mynode] #show database synchronize
Last L2 synchronization time: Standby not synchronized since last reboot
Last L3 synchronization time: Wed Mar 14 09:57:21 2018
To Master Switch at unknown IP address:  succeeded
To Secondary Master Switch at  succeeded
Re: Mobility Master L3 Redundacy
Hi, please ignore have answered my own query.
Secondary master is configured during full-setup:
This device connects to Master switch via VPN concentrator (yes|no) [no]:
Is Master switch Virtual Mobility Master? (yes|no) [yes]: no
Master switch Authentication method (PSKwithIP|PSKwithMAC|FactoryCert) [PSKwithIP]:
Enter IPSec Pre-shared Key: *********
Re-enter IPSec Pre-shared Key: *********
Do you want to enable L3 Redundancy (yes|no) [no]: yes
Enter Secondary Master switch IP address or FQDN:
