Contributor I
Mobility Master - Managed Device - Show configuration
I would like to see the running configuration of the Managed Network Group, any way to see this?
If i navigate in cli to /md/GroupName/ and do a show configuration, it just gives me the config of the /mm/ node.
As i need to do a lot of similar creation of Roles, Policies, AP Groups, Authentication servers / groups, etc. it would be preferable to do this via cli.
Regards
Kevin
MVP
Re: Mobility Master - Managed Device - Show configuration
Hi Kevin,
have you tried show configuration effective?
You go to cd /md/YOUR_GROUP and run the command.
Also, you can do show ap-group ? and it will show you all the AP groups in the GROUP. Same with other profiles like SSID, AAA, VAP's, etc.
Borja
ACMX #567 //ACCP//CWNA//CWAP
Contributor I
Hi Borja,
That worked! Thanks a bunch for the quick reply :)
Frequent Contributor I
You can also try 'show configuration committed' to see the non inherited configuration of that folder.
#AirheadsMobile
