Occasional Contributor I
Mobility Master/Mobility Controller Crash ( No trusted VLAN)
Hello I have a problem with aruba OS
Model:
ArubaMM-VA
Version:
8.3.0.0-beta
MAC address:
00:50:56:8A:0B:24
Compiled:
2018-02-15 at 23:16:33 UTC (build 63709) by p4build
I am trying to set up a demo lab for client with aruba branch solution.
How to clear crash errors from MM? Or how to repair them?
Because  now I can't change part  configuration of mobility controller.
Is it possible some how to revert configuration to time before crash?
crash happened when I was testing  Inside and Outside NAT configurations
 Here is some info from MM
(VMM) *[mynode] #show  crashinfo
Crash Info Table
Crash Time              Process Name
March 28 13:00          profmgr
Re: Mobility Master/Mobility Controller Crash ( No trusted VLAN)
Add report
