Occasional Contributor I
Mobility Master hardware installation weird issue
I am in the position of installing, 2 * Mobility Master (10K) hardware devices and 5 * 7200 Controllers.
The installation of the MM hardware appliances was looking good until, command line looked normal for OS8 can see
(GCC-DV-MM-01) [mynode] #cd /mm
(GCC-DV-MM-01) [mm] #
, ( I have already setup a test lab using virtual versions of the MM and WLC using OS8 prior to this install)
I logged into the web gui and i found an unusual issue, one of the MM seems fine as expected but the other MM has the same gui presentation as a WLC. see screen shot.
Is this a build issue? wrong licenses added in production
Dave Stalker
Re: Mobility Master hardware installation weird issue
Did you try clearing your browser cache?
The browser works fine with the other MM? and I only noticed there was an issue when i typed
show license passphrase
and it said command unsupported, i was consolled onto the device?
thanks for your swift reply
Dave
sorry not a browser caching issue im afraid
thanks
Dave
Please open a support ticket so that it can be looked at:
http://www.arubanetworks.com/support-services/support-program/contact-support
Super Contributor II
Hi!
The "Command is not supported for this platform" when you issue
*[mynode] #show license passphrase is expected when you run on a hardware mobility master.
It really looks like if your browser still has things cached for that particular IP/hostname. Have you tried CTRL+F5 and other browsers?
Do you have both MM setup in redundancy now? What does "show switches" and "show switchinfo" from your MMs tell you?
Cheers,
Christoffer Jacobsson | Aranya AB
Aruba Partner Ambassador
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
The device i am installing is a hardware device so should be a useable command?
Sorry i tried that no luck, also if it cached it from a previous controller would it update the name and the hardware version? and the other MM works fine and dandy ?
is there a way to blank the hardware device and build it from scratch, using ova, iso file?
thanks
Dave
I saw this recently and after restarting the MM it was fine..didnt get a chance to open a case tho.
Are you using any APs that required 8.3.x ? or particular feature in 8.3.0?
If not i recommend to go with 8.2.1.1 instead
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thanks for that i shall give it a try, unfortunately it shall not be until next week installed in a new Data Centre with no remote access! looong story lol
I shall also bare in mind the OS recommendation just went for the latest one as that is just about always the first thing TAC case say are to blame but a rollback might be worth a shot also
thanks again
Dave
Thanks all,
The Device just needed a manual power down and everything was fine, just a glitch in the matrix
thanks
Dave
