Occasional Contributor I
Mobility Master in AWS
At the moment we have a dozen offices, each with dual controllers running 6.2 in master active/standby mode...
We would love to upgrade to version 8, and use the benefits it provides, but finding it hard to do so.
You see each of our offices have no servers, simply network gear, conencted to the internet & AWS.
The dilemma i have is that i cant spin up a mobility master in AWS.
Is this possible, if not is it on the road map, and finally is there an alternative solution?
Re: Mobility Master in AWS
I recommend reaching out to your local Aruba account team/SE for options and any roadmap information they can share.
Charlie Clemmer
Aruba Customer Engineering
Hey,
you might want to check this out:
https://cloud.vmware.com/vmc-aws
This looks to me like it could work.
My normal solution would be to rent a server or two in a datacenter and Install a vm-hypervisor you like and simply spin up the VMs provided by aruba. Maybe Proxmox is a cheap and easy solution for this.
Greetings,
Hendrik
WiFi Enthusiast | ACMP
Thanks for the recommendation.
Unfortuantely neither work for us, so my guess is we will have to wait or look at other vendors..
Ivan,
Please contact your Aruba representative to understand your needs.  ArubaOS 8.x is new, but depending on what you are trying to accomplish, it is not a requirement.
