Mobility controller layer 2 deloyment
  • 1.  Mobility controller layer 2 deloyment
    Posted May 18, 2015 01:43 AM
    Currently i have 10 105 APs and they are managing through Virtual controller.And layer 3 switch are using for intervaln routing.
    We are planning to deploy Mobility controller.Please help me out how i deploy Mobiliity controller as layer 2 device.But i don't want to change my current  design.Right now all ports from switch to IAPS are trunks,and all VLANS are configured on layer 3 switch.
  • 2.  RE: Mobility controller layer 2 deloyment
    Posted May 19, 2015 10:47 AM
    HI,
    Please get me more clarity on this. You want to deploy Controller in the place of existing L3 Switch ? or you want to deploy Controller fro an other wireless deployment ?
    Please clarify the above ,I can help you on this.
  • 3.  RE: Mobility controller layer 2 deloyment
    Posted May 19, 2015 12:21 PM
    You would simply define and trunk all of your VLANs to the controller and recreate the necessary configuration.
  • 4.  RE: Mobility controller layer 2 deloyment
    Posted May 19, 2015 11:28 PM
    I need to know the port where i connect controller it should be access port (part of managmenet VLAN) or trunk??
  • 5.  RE: Mobility controller layer 2 deloyment
    Posted May 19, 2015 11:30 PM
    If there are multiple VLANs, then it needs to be a trunk.
    Tim
  • 6.  RE: Mobility controller layer 2 deloyment
    Posted May 19, 2015 11:33 PM
    yeah current  i have Multiple SSIDs on virtual controller and all are the part of different VLAN.
  • 7.  RE: Mobility controller layer 2 deloyment
    Posted May 20, 2015 05:38 AM
    as per my understanding, you are trying to uplink the controller to a switch which will forward the client traffic . when you have configured different VLANs for each VAP ( Virtual AP ) you need to configure the uplink port ( Port which is connected to L3 Switch) as Trunk and you need to allow VLANs as per the requirement.
    Configuration is similar to Cisco switches,
    interface Fa/Gi <port id >
    Switchport mode Trunk
    Switchport trunk allowed vlan < list of VLANs>
    switchport trunk native vlan < VLAN>
    To verify use , show trunk
