Occasional Contributor I
Mobility controller (not responding)
My demo controller (W-620) full licensed has a problem with his
/mswitch/bin/wms              PROCESS_INITIALIZING  -                 131       240            4                Tue Nov 29 01:59:10 2011
I think.
This was under 6.1.2.3, so I upgrade it to 6.1.2.4 but I have the same problem.
After three (3) clicks I don't receive any response within AP Installation, then I checked the process (show process monitor statistics) where the above line was very high after (131 restarts within 10 minutes)
Is there something else that I can check?
Danny
SE @ Dell
Networking Domain
Re: Mobility controller (not responding)
Please open a TAC case for that one.
The only thing I think you can try is "process restart wms core".
If that does not work, start completely from scratch:
- Save your license keys
Do a "wms reinit-db" and reboot
If that does not work, save your license keys and then do a "write erase all"
Joseph,
Likely that with this problem also my Captive Portal doesn't work?
I was testing the CP for a customer where it don't work and I didn't get it working on my LAB controller.
I will open a Case.
Thnx.
Danny
SE @ Dell
Networking Domain
Regular Contributor I
Any update on this issue?
what I try to do is a "wms reinit-db" but the system is saying.
(ADK-620) #wms reinit-db
RF-Plan data and WMS Database will be re-initialized.Do you want to proceed with this action [y/n]: y
Module WMS is busy. Please try later
After a reload I still have the same problem.
Are there other commands that I can try that I don't know?
Danny
SE @ Dell
Networking Domain
Re-installing the software and start from zero.
This helps, sames that the other partition (software) was corrupt.
Thanks for all the help you all give.
Danny
SE @ Dell
Networking Domain
Hi ,
This is muthu . I have configured 3200 controller .and 105 Ap . after cnecting network i am getting error messge
Muthu,
Please open a new thread for this issue.
