Contributor II
Mobility domain config guide
I've been doing some studying for my ACMX written and I've come across the Mobility Domain subject.
Ran into this section in the configuration guide and I was wondering if the second entry in the HAT table is a typo? I want to make sure i'm not missing something...
To me it appears that entry 2 should be either directed to controller 1 or the network should be a 10.2.x.x:
10.1.1.0
255.255.255.0
1
10.1.1.245
10.1.1.0
255.255.255.0
1
10.2.1.245
Can someone clarify if it is not a typo?
-Joey
Re: Mobility domain config guide
Looks like that whole 2nd line is a typo.
Cheers
James
