Mobility master and VMC
I have noticed two new types of controllers on the IRIS configurator recently which are the virtual mobility controller and the mobility master found with OS 8.0.
I tried reading few things but the difference between these two is still not clear for me.
what are the main differences between theset two and where to deploy each?
Re: Mobility master and VMC
The Mobility Master is a new component of the Aruba architecture that enables customers to take advantage of advanced features that require central coordination and for networks to scale due to increased demand for mobile and IoT devices. It also replaces the prior functions of the master controller and can be either deployed as a VM or an x86 hardware appliance. The Mobility Master provides automatic RF optimization and enables hitless failover in an unlikely event of a controller outage.
AOS 8 Datasheet.
AOS 8 release notes.
Both the links with provide lots of info. :)
Cheers
James
Thanks for your reply.
So one more thing, in the deployment where do I need to place only a local/ master and where to position  a master controller with a  mobility master?
Work directly with your Aruba SE to flesh those questions out. The main thing is you have to decide or know if, in 8.x you want to leverage the features on the Mobility Master (Clustering, NBAPI, Airmatch, etc) or not. If they are not critical to your need, then you can go with 8.x on a controller without MM. If you do want those features, you need the Mobility Manager.
but your local HPE Aruba SE can better work through those questions than here.
Jerrod Howard
The ArubaOS 8.0.1.0 Release Notes refer to:
Aruba Mobility Master and VMC Installation Guide
but I've tried a number of searches and keep coming up empty.
Here you go:
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=23611
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect
Here you go:
Get Outlook for iOS
Thank you
Victor Fabian
Hi guys,
One question about this. I have two 7205 controllers in HA mode. I want to take advantage of advanced features of the Mobility Master component with the VA type. Do I need to replace my 7205 controllers with the Mobility Master VA or do I need to only add the Mobility Master VA to my network keeping my 7205 controllers operational?
Julián
Add a MM
Tim Cappalli | Aruba Security
