DSP
Contributor II
Module WMS is busy. Please try later
Hello All,
I am hitting this error message when attempting to importa WMS DB from a M3 controller into a 3400.
AOS 6.3.1.15 Does anyone knows how to workaround this or if I am missing something ?
DSP
Re: Module WMS is busy. Please try later
What are you trying to do ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Trusted Contributor I
does this happen when you start the import or later? messages like this for different Modules sometimes just point to a temporary situation which becomes normal later on.
